Getting new rear end, i'm clueless
Old May 29, 2001 | 10:06 PM
PullmeoverRed's Avatar
Ok, I have a 1992 Camaro RS w/305 TBI(350 TBI soon. As far as I know, I have the 700r4 tranny with 2.73 rear end. I want to put 3.42's and a posi rear end on it.
What kind should I get?
What benefits would I get from it?
What problems would I run into?
Thanks all
Old May 30, 2001 | 12:08 AM
USNTimbo's Avatar
Hi,
I have an 86 Z28 and just two weeks ago had the rearend ratio replaced. I went from a 2.73 to a 3.73 rearend ratio. I chose Richmond Gears. This will really liven your vehicle up... I dont know what all you've done to it, but I dont have anything mechanical that is original, and the 2.73 was just bogging down the whole vehicle.
You will notice great throttle response and acceleration off the line, and less top end speeds. As long as you have overdrive, gas will not be too bad... I haven't noticed too much a difference, at least on the street...
You will have to recalibrate your speedometer... I have yet to do this, but the parts are available.
I recommend using redline gear oil, at least thats what was recommended to me.
Best of luck, if you have any other questions, feel free to email me.
Tim
Old Jun 4, 2001 | 11:27 AM
Great acceleration, are we talking seat of the pants difference? Also, did you get a posi rear end? What the hell is a posi rear end? I heard that helps too, and I'm going to get both.
Thanks man,
Dave
Old Jun 5, 2001 | 07:11 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
With a posi rear end both tires spin at the same time no matter which has greater weight on it, thus when you do a burn out instead of one black mark you will have to. A posi is good if you have a lot of power because it allows the power to be distributed to 2 wheels instead of all power to one wheel.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out
"There is nothing more addicting than speed"
Old Jun 5, 2001 | 07:14 AM
Car: 99 Formula
Axle/Gears: 342
Oh, and I believe a posi will give you better handling especially going into turns.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
B&M Megashifter
Exhaust Cut-Out
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
