Cruise Control Delete
Old Mar 1, 2009 | 11:49 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
I want to get rid of all the cruise control unit under the hood, all i know that has to do with the CC is the plunger thing behind the headlights. What else can or has to be removed? I want it gone as it does not work anymore and i don't drive this car on the highway anyways.
Old Mar 2, 2009 | 02:50 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Cruise Control Delete
I am hoping ppl have pictures.....
Old Mar 2, 2009 | 02:54 PM
v10viper04's Avatar
Engine: LT1, L99
I this part of the cruise control?
Old Mar 2, 2009 | 03:26 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
That's the actuator. There's a vacuum ball for it, on the underside of the tray. There are vacuum hoses running to it from the plenum, and the brake pedal. Finally there's an electronic module in the dash, near where a glove box would normally be. You'll trim a good 3 lbs off the car by removing everything.
Old Mar 2, 2009 | 03:28 PM
v10viper04's Avatar
Engine: LT1, L99
SO the vaccum lines need to be removed/plugger and the ecu for it removed.... will that affect anything electronically? Thanks
Old Mar 2, 2009 | 03:33 PM
85MikeTPI's Avatar
It's a totally independent system. You could just remove the vaccum line from the plenum and plug it, and the system won't operate or throw any codes..
Hotrodboba400
Dec 10, 2019 07:07 PM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
