NEED SOME HELP. PLEASE!!!
Old Jun 5, 2001 | 10:20 AM
A2Z87IROC's Avatar
I installed a shift kit in my 87 700R4.
No problem, except, I noticed today when I was fixing the leak I created by tearing the boot that goes around the dipstick as it goes into the tranny, that all the bolts around the perimeter of the pan were loose?!
What would cause this, what can I do to fix them so they stay secured? Also, my pressure regulater, with reverse and TV valve keeps dropping out of the bore, the retainer that fits into the groove at the bottom of the bore keeps popping out, I'm not sure what's going on with that, am I creating too much pressure in my tran. or is the retainer weak? Any help on this would be greatly appreciated...
87 IROC z
5.7L TPI 350
TOO MANY MODS TO LIST
"Pardon my noise, its the sound of freedom..."
Old Jun 5, 2001 | 11:41 AM
Ezey Go's Avatar
Snug your bolts down real good and if they come loose gain use Lock Tight on them.The only problem with that is changing your fluid.As for the TV clamp make sure its actually in there because they are a real ***** .If just the slightest part of the clamp is out of the groove it wont hold.I hope this helps.
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
