which is better
Old Mar 2, 2009 | 11:19 PM
kccisco's Avatar
Car: 85 transam
Engine: 76 chevy 350 carb
Transmission: t-5 3.23
which is better
iv looked but cant find this one. which would be better for speed, changing the gears in my t5 or changing the gears in the rearend cause i just swapped the tbi 305 motor to a 350 carb with 305 heads, performer intake, and a holley 650 demon carb and when i drive it it feels as if the motor isnt even sweating at all so i want to change the gears in the tranny and the rearend but due to money issues im going to have to focus on one at a time. so which should i do first that would give me a noticable boost.
Old Mar 3, 2009 | 01:02 AM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Re: which is better
You only need to do one. The rear end is the best to do. 373's rule.
Old Mar 3, 2009 | 01:22 AM
kccisco's Avatar
Car: 85 transam
Re: which is better
well that makes things cheaper since i was planning to do 3.73 gears in the rearend cause i talked to a wreckin yard and he said he had a set that he would sell me for cheap.
Old Mar 3, 2009 | 06:35 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: which is better
Cheap gears and rear gear change should NOT be used in the same sentence. Do a lot of reseach before even thinking about buying parts. Numer one, is what is in the rear NOW?? Then go from there, just my opinion.
Old Mar 3, 2009 | 06:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: which is better
If you're thinking about changing gears, take a look at the following link for some info that you may not have considered:
https://www.thirdgen.org/forums/tran...-10-bolts.html
Or as DJP sometimes points out, a rear end swap might be more cost effect than changing gears.
JamesC
