Is a ZF6 compatable?
Old Feb 24, 2009 | 10:38 AM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Hey I found a ZF6 tranny out of a c4 vette. can this tranny work in my 83 camaro? will it bolt to my bellhousing or could I make an adapter plate? anybody have any experience with these?
Old Mar 2, 2009 | 08:16 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Is a ZF6 compatable?
It's not an ideal swap, but is possible with some parts/$/work..
From CHP:
To install it in a early Chevelle, for example, requires a Corvette bellhousing, flywheel, hydraulic clutch assembly, drive-shaft yolk, and a custom crossmember. The ZF is 2 inches longer and 3.5 inches taller, requiring the floorboard in the car to be heavily modified and making it a less-than-ideal candidate.
Old Mar 2, 2009 | 11:47 AM
brodysZ28's Avatar
Engine: 383
hmmm so t56 is a much better choice?
Old Mar 2, 2009 | 11:57 AM
85MikeTPI's Avatar
The T56 is almost a bolt in, so I'd say yes it's much easier.. It's also pretty well documented. The ZFs go pretty cheap, because no body wants them except LT1 corvette owners... YMMV
Old Mar 2, 2009 | 01:15 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
There are talks within Mcleod to make a direct fit bell for the ZF box. Problem is there were 3 different housings made. The ZR-1 housing, a magnesium L-98 housing and a Aluminum LT housing. All were different dimensions. Call Red Roberts at Mcleod (714) 630-2764 X 225 for more info.
Old Mar 2, 2009 | 04:20 PM
brodysZ28's Avatar
Engine: 383
Is the only thing holding this back from being a direct bolt in the right bellhousing?
Why is there not an adapter plate to bolt it to our bellhousing?
Old Mar 2, 2009 | 07:54 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Id stick with a LT1 T56. bolt on, more recent design, can probably take the same amount of beating... if not more.
Old Mar 3, 2009 | 12:29 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That and the T56 is easy to get parts for if needed. The ZF is d*mn near impossible to get parts for, especially if you need them fast. And they are scary expensive too. T56 parts are relatively cheap.
Old Mar 3, 2009 | 10:07 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
I second that..
tmellott89
Oct 14, 2015 02:06 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Formula_88AE
Sep 3, 2015 01:47 PM
