Converter Recommendations?
Old Jun 4, 2001 | 10:14 AM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
I am looking for apx 2400 stall to add within the next month and I would like to get a recommendation on what brand converter to use.
I have heard bad news from B&M and cheap summit converters. Good & bad from TCI (decent cost). And all good stuff form Vigilante (but way too $$). Local shops use buckeye which I have never heard of.
I would like something reliable and good but I of course don't want to spend too much $. In the future I am planning on adding some more horses so I want something that will handle the abuse too.
'84 Camaro w/ Large Jouranl 327 bored .030 over; 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
Work in progress is Sponh Torque Arm just installed working towards 2400 stall convertor. www.chartermi.net~brodgers
Old Jun 4, 2001 | 02:02 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
I know you may be impatient, but your best bet is to change the convertor only once...
And one of the best out there is Vigilante..
I strongly recommend it, and you've already said people say good things about the convertor..
Save up the money awhile longer, don't let it burn a hole in your pants, and you will truely think it was worth while if you get the Vigilante
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven
Old Jun 4, 2001 | 03:09 PM
transfixleo's Avatar
The number for Continental Converters in Inglewood Ca. is 1-310-674-1072
Old Jun 5, 2001 | 06:42 PM
Pro Built Automatics's Avatar
If you are running the TH350 transmission the I would use the 10" from Continental apx. stall 2,500 rpm. They sell for $365.00, give me a call if you need one. 800 7763288 Mon-Sat 11-7 PST and I will answer any questions you might have concerning this.
Hope This Helps!!!
Old Jun 5, 2001 | 06:44 PM
Hope This Helps!!!
Old Jun 5, 2001 | 06:45 PM
Hope This Helps!!!
Old Jun 5, 2001 | 06:47 PM
Hope This Helps!!!
Old Jun 5, 2001 | 06:52 PM
Hope This Helps!!!
Old Jun 5, 2001 | 07:18 PM
Hope This Helps!!!
Old Jun 6, 2001 | 04:47 AM
Hey Pro Built, Do you stock the continental converters?
Old Jun 6, 2001 | 07:24 AM
Sorry, for the repeat of my message, I thought it did not accept it. I can see that I was wrong. I have been a distributor for Continental for the last 21 years. I do not keep TC's in stock anymore, due to the costs of the TC's & varibles of each torque converters. Usually it takes 2-4 days to have Kris build a TC to match whatever transmission I am working on or what I need for a particular customers order.
Hope This Helps!!!
Old Jun 9, 2001 | 06:00 PM
ATTNGETR's Avatar
Car: 86 Iroc
Engine: tree-fiddy
Transmission: hmm..a 700 or a T5..guess!!
Well on the East side of the states you can give Pro-Torque a call at 1-631-218-8700 you can ask to speak with Joe and he will be able to dial up a good converter for your application,or drop them an e-mail at www.pro-torque.com hope this helps!!!!
86 Iroc-Z28 350 Edlebrock,Borla,Transgo,B&M,ACCEL,Random Tech,Auburn,Alpine,Rockford Fosgate,Ultra Z's,1LE brakes&swaybars etc....
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
