Need help selecting a new rear end !!!!!!
Old Jun 8, 2001 | 10:35 PM
83_TA's Avatar
I have an 83 TA which is NOT Posi. I just had my motor rebuilt & would like to put in a new rearend with Limited Slip..
Basically I have no idea what I'm looking for.. I currently have rear disk brakes & I think 3.23 gears..
Do I just need to have the differential replaced & a new set of 3.73 gears, or do I need to replace the entire rear end?
If I replace the entire rear, what would I replace it with?
Any help & technical advise would be greatly appreciated..
Old Jun 9, 2001 | 06:20 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
you can keep the housing,ring gear and posi unit ect... will cost $500-600 and you should have someone do it for you if you've never done it. removing and replacing the rearend is easy though. good time to add some springs,shocks & hothkis LCAs & panhard bar,good stuff. I have an '84 w/ a 5.0 HO,700r4,3.73 limited slip posi,it's a great gear ratio for this engine.
Old Jun 9, 2001 | 09:41 PM
83_TA's Avatar
Thanks for the advise.. I currently don't have Posi.. I'm looking to have a Posi rear put in or convert my existing to Posi..
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
