700R4 REFUSES to shift out of 1st gear
Old Jun 9, 2001 | 01:43 PM
Team FTS's Avatar
My 700R4 is holding on to first gear while in D and OD if i manually shift it in to 2nd it shifts but then holds that gear.
Old Jun 9, 2001 | 02:19 PM
KED85's Avatar
Dirty valve body.
I had that happen, but, only stayed in first.
Then I got it to JUMP from 1 to 3.
I lost band on the drum.
Ungunked the valve body, too.
Good luck, I've learned alot here.
Next is recalibrating (one tranny) and also rebuilding a bad tranny
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 9, 2001 | 04:13 PM
transfixleo's Avatar
By any chance does it seem to go into gear rougher than usual now too? If so it confirms that the TV Valve is stuck (common cause fo failure). If the fluid doesn't exactly look perfect, you know what is next, right?
Old Jun 10, 2001 | 04:05 PM
Team FTS's Avatar
Well the tranny fluid is a brown color I am sure that is bad but i don't know why.and thank's for the above responses, I know nothing about trannies so i need all the help i can get
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
someone972
Aug 30, 2015 12:52 AM
mizz0313
Aug 12, 2015 06:45 AM
drathaar907
Aug 6, 2015 04:20 PM
