How hard to switch from rear disk to drums?
Old Jun 10, 2001 | 12:01 AM
83_TA's Avatar
I currently have a 3.23 non limited slip rear end with disk brakes..
I have the opportunity to purchase a new rear end which is 3.73 Richmond gears and Posi., but the only thing is the rear end has drum brakes..
Is this going to be more trouble than it's worth, or is it a fairly easy thing to do?
Thanks..
Old Jun 10, 2001 | 06:03 PM
AfootVoyager's Avatar
it will bolt right in....very easy
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
plain firebird nose(for better engine cooling)
T-Tops, pwr everything
been to about 140mph
Old Jun 10, 2001 | 06:29 PM
83_TA's Avatar
What type of conversion will I need to do for the brakes? Going from disk to drum, or is it a bad idea? Should I just try to find a Posi rearend with disk brakes..
Old Jun 11, 2001 | 12:03 AM
83_TA's Avatar
Anyone else have any suggestions?
Old Jun 11, 2001 | 12:36 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
you may need the brake lines from a V8 camaro and the master cylinder up front from a V8 Camaro that has disks all the way around that way it will be equal in braking, thats what I would do just to be sure.
Old Jun 11, 2001 | 05:49 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Why don't you just take the components out of the drum setup, an install them into your disc rearend?
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jun 11, 2001 | 11:03 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Both rears are 7.5....keep the discs (better stopping power) and just switch the posi & gears.....
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Old Jun 11, 2001 | 03:30 PM
shutch's Avatar
i'd have to agree. i would certainly swap the gears and keep the rear discs.
Orr89RocZ
Apr 25, 2016 08:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
