swapped to th350?
Old Mar 7, 2009 | 06:56 PM
1BADTPI's Avatar
swapped to th350?
i swapped my 700r out for a th350 in my 91 trans am with a 350tpi motor.What all do u guys do about the speedo cable since the 700r in electirc? and will not havin the speedo hooked up mess with the computer any or can i just cap off the speedo spot on my th350 and b done?
Old Mar 9, 2009 | 02:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: swapped to th350?
I think you can use an electric VSS for a TH350. Yes the computer requires the signal from the trans to tell it the car's speed or it will set an SES light and not run right.
Old Mar 9, 2009 | 11:50 AM
1BADTPI's Avatar
what pulse speedo senor does the car have aint it like a 4k?
Old Mar 9, 2009 | 11:37 PM
Kevin91Z's Avatar
Yes the 90-92 TPI f-bodies use a 4000 pulse speedo.
LittleFranks
Sep 17, 2015 12:22 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
