168 tooth flywheel work w/ T5 and Tremec?
Old Jun 11, 2001 | 04:48 PM
Camaroman's Avatar
I have a 454 and I need a flywheel...
the only ones ive seen sold are 168 teeth...
i have a 305 that came w/ the T5 but I figured its probaly different and might as well get SFI appoved
So I guess my question is...will the 168 tooth work w/ the T5?
Also will I need a new starter?
Old Jun 11, 2001 | 09:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, the 168 tooth flywheel wont fit. Not to mention, the 454 will KILL the T5 pretty quickly.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 12, 2001 | 01:43 AM
87RS402's Avatar
You HAVE to use a 153 tooth (12-3/4") wheel. The T-5 bellhousing will not fit around a 168 (14")wheel.
The 454 is also externally balanced. You would need to get the flywheel rebalanced for it. Then enjoy it while you can, that 454 will grenade your T-5 in short order.
hot92z
Feb 23, 2005 09:38 AM
hansb
Aug 1, 2004 03:17 PM
johnyIROC
Dec 23, 2003 07:40 PM
BANDITSBC
Jul 31, 2003 10:51 PM
QwkTrip
Pacific Northwest Region
Jan 13, 2002 06:55 PM
