Trans output shaft slop
Old Jun 9, 2001 | 04:00 PM
Chris 611's Avatar
The output shaft coming out of the rear end of my trans on my '91 formula 350 has some slop it in (.06") When I rotate the driveshaft by hand with the trans in Park, it makes a clunking noise in the rear extension cone. Is there a bushing or bearing in there that is worn out? Any help would be greatly appreaciated. Thanks.
Chris
Old Jun 9, 2001 | 07:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a bushing in the tailshaft housing. It is fairly easy to replace: The housing has to be out, and it should be done with a press.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 11, 2001 | 10:50 AM
Chris 611's Avatar
Thanks for the reply. Does the bushing sound like a good bet for being the problem or do you think it is something else?
Old Jun 11, 2001 | 07:47 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
There's also a bushing where the output shaft leaves the case. Is the play more side to side or front to back.
Check your U-joints first though... Also alot of backlash in the rear gears may clunk in gear. Also the early 700r4's had no accumulator for neutral (or park) to drive/reverse so they tended to slam into gear. Also too high an idle can cause this...
Old Jun 12, 2001 | 07:31 AM
Chris 611's Avatar
The play is side to side. Whats the best way to check the u joints. Right now I just grab the output shaft and drivshaft and turn them in opposite directions and look for play...is that the right way? I will have to check the rear end lash also. I have noticed that the rear diff. gets hot after driving, I don't know if this is normal or not. Thanks for the help.
Old Jun 12, 2001 | 08:06 PM
JoelOl75's Avatar
It's better to drop the driveshaft to check for play as you may be seeing some lash between the splines on the output shaft, ect...
Just try twisting the u-joints in every direction and if there's any play at all they're no good. Sometimes they make a clicking noise when you try to twist them by hand. They are retained by injected plastic, so you need to melt the plastic with a propane torch if you plan on replacing them yourself. The replacements are held in with the snaprings or tru-arcs.
Amillionoh7
May 24, 2020 08:01 AM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
MENINBLK
Aug 5, 2015 11:58 PM
