No computer 700 r4 please read
Old Apr 16, 2001 | 02:03 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I just looked in the jegs cataloge and they have this thing made by TCI that lets you get rid of your computer from your transmission.My question has anyone used this thing its called GM200/700R4 TORQUE CONVERTER
LOCK UP KIT page122 Im in the process of getting rid of my computer and i was wondering if it any good.....
THANK
Old Apr 16, 2001 | 04:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Jegs' P/N 890-376600? That's what you need.
Old Apr 16, 2001 | 04:20 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I know the part number.I was wondering if the thing really works
Old Apr 16, 2001 | 08:06 PM
82camaro's Avatar
Car: 82 camaro SC
I got one, it works. Currently I have bypassed the vacuum switch part of it. It locks up when it shifts into 4th gear AND the switch I added is turned on. With the switch off, it never locks up. I did this to have more control. The vacuum switch did work, before I bypassed it.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jun 14, 2001 | 02:54 PM
87formula's Avatar
Did you notice any difference in quality of the shifts or anything to that effect?
Thanks a bunch.
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
1987 Firebird Formula
305 LG-4
GM Vortec heads 2.02x1.6 valves
Crane CompuCam 2030
700-R4 Trans
4 barrel quadrajunk remained by holley (this carb stinks!!!)
edelbrock performer intake
Hypertech Thermomaster Chip
Open Element Air Filter
No Cat with Straight pipe (Dynomax muffler rusted apart and fell off probably could not stand the heat )
Accel H/P Coil
- Soon to be installed
383 stroker (built and ready)
NO MORE COMPUTER CRAP
700R4 Lockup kit
Edelbrock TES
True Dual exhaust or 4 inch single pipe to dual 2 1/4"
Stall convertor
Old Jun 14, 2001 | 03:50 PM
82camaro's Avatar
Car: 82 camaro SC
Shifts are the same since the computer doens't have anything to do with the shifts.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkim bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jun 14, 2001 | 05:21 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Yeah, It shifts the same i have in my car now.It a great little device....
1987 BLUE IROC
IT'S A DOG
BUT IT'S MY DOG
AND IT HAS A NASTY BITE......
CNYFBA MEMBER
http://cnyfba.cz28.com/
eightsixseven
Dec 16, 2024 01:50 PM
Elephantismo
Feb 13, 2019 12:51 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
GTAman
Sep 21, 2015 09:57 AM
87hellbird
Sep 14, 2015 05:08 PM
