700r4 CLUTCH?
Old Mar 11, 2009 | 10:18 AM
TAGTASCOTTY's Avatar
Engine: 408ci Stroker, 520hp 515Ft.Lbs.
Transmission: Outlaw 700r4
Axle/Gears: 3:73
700r4 CLUTCH?
Ok, due to a fualty t.v. cable, I can no longer get 3rd gear, my question is can the band be tightened or anything for that matter, or am I screwed? Any help would be GREATLY appreciated. Thanks Guys!
Old Mar 11, 2009 | 11:01 AM
Axle/Gears: 3:73
Re: 700r4 CLUTCH?
If it helps any, I was not getting on the throttle at all when it would not shift to 3rd, just rev'd real high in 2nd
Old Mar 11, 2009 | 05:49 PM
jonarotz's Avatar
Car: 91 Z28
Re: 700r4 CLUTCH?
The band is only applied in 2nd and 4th so I don't think that is your problem. Besides there is no adjustment to make. More than likely your 3-4 clutch is smoked. Pretty common.
Old Mar 12, 2009 | 10:03 AM
Axle/Gears: 3:73
Re: 700r4 CLUTCH?
Yeah I figured as much, just kinda hoping though, I changed a bunch of trannies in my time but never rebuilt one. Nice car by the way too. Very Nice. Thanks man
Old Mar 12, 2009 | 12:04 PM
jonarotz's Avatar
Car: 91 Z28
Re: 700r4 CLUTCH?
Thanks, I would pull the pan first and see what kind of stuff you have hiding in there before you tear it out and apart.
Old Mar 12, 2009 | 04:56 PM
Axle/Gears: 3:73
Re: 700r4 CLUTCH?
As far as what? Like metal shavings, or valvebody or something?
Old Mar 12, 2009 | 09:45 PM
jonarotz's Avatar
Car: 91 Z28
Re: 700r4 CLUTCH?
metal shavings and clutch debris.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
