1987 stock rear end question.
ok this is my first post and i just purchesed a 1987 camaro for a project car. it orgianlly had a v6 in it. But from what i understand it has a 350 from what i was told. i will check the numbers to make sure if its a 305 or 350. but what i was wondering. he told me the rear end was stock and i was wondering if they come open or locked with posi or what?
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: 1987 stock rear end question.
If it was a V6 it is most likely an open 3.42 diff. as long as its stock
Look here.
https://www.thirdgen.org/1987-chevy-camaro
Look here.
Look here.
Look here.
okay open means it will only spin one tire with less tranctions correct?ok i would like to lock it up where both woulld spin. how much would i have to spend to do that and would it be a diffucult process. sorry my spelling is not all that correct.
Car: 89' IROC-Z
Engine: LO3
Look up Posi or Limited Slip Differentials otherwise known as LSD's, also there are Lockers too, Like detroit lockers, but i dont know much about those and if they are similar to a posi/lsd unit.
As far as I have seen they very from brand to brand. Have seen some from $500-$2000, and if you don't know how to install one it would be best to have someone do it for you. Someone who has done this before or knows how will be able to get it done fairly easy i think.
Start searching the forums. Figure out what rear end you have (Pretty sure its a 7.5 GM 10 bolt), then what LSD units fit, then price and compare.
Take a good time learning about these units. The brands, how they differ and what they are best used for.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. Many of your questions can be answered with a search. Check the following sticky:
https://www.thirdgen.org/forums/tran...-10-bolts.html
If after reading the above, you have further questions, let us know.
JamesC
JamesC
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It "may" not be a 10 bolt so the FAQ might not help. If the original engine was only a V6 then it will be a 10 bolt.
I recommend the Eaton Posi. They are rebuildable, tunable and will last a long time. They work well on the street as well as moderate drag racing. You will need the Posi, bearings and shims to set it up. I can connect you with a link that will explain how to install it. You will need a dial indicator with a magnetic base, a micrometer and a torque wrench. I can get you the Eaton for $435.
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
i guess it also veries on the seller. i found a 9 bolt with a 3.73 posi (used but not worn badly) for 150 bucks OBO on craigslist. (i know craigslist isnt always accurate but for 150 bucks you cant really go wrong)
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
