Gears
Old Mar 11, 2009 | 05:12 PM
pgh1992's Avatar
Car: '92 Camaro
Gears
How hard is it to change the 2.73 stock gears to 3.73? How much would it cost? It a '92 RS with the Lo3 and 700r4 trans
Old Mar 11, 2009 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gears
Welcome to TGO. Check the 10-bolt sticky at the top of the page. Many of your questions will be answered there.
JamesC
Old Mar 12, 2009 | 12:04 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Gears
I've tried that combo. It's too much gear for a stock LO3.
Old Mar 12, 2009 | 01:10 PM
pgh1992's Avatar
Car: '92 Camaro
Re: Gears
Is there anything else that i can put in or am i stuck with the stock gears?
Old Mar 12, 2009 | 02:29 PM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Re: Gears
I purchased a rebuilt govloc off ebay for $210 shipped, my NEW 3.73 gears were $115 shipped and bought jegs mega install kit for 129.00 plus 12.00 shipping.That kit includeds bearings, shims, pinion seal, axle seals and axle bearings. Really not to badly priced but I sit back and wait for deals to pop up!
Old Mar 12, 2009 | 03:35 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: Gears
I got them in my car i think it fun im at 2k rpms at 60 mph. Think just the labor cost me around 5 or 6 hundred.
kevin
Old Mar 12, 2009 | 05:49 PM
big gear head's Avatar
Re: Gears
The 2.73 uses the 2 series differential. You are going to need a 3 series for the 3.73 gears, or anything from 3.23 to 4.10. I recommend a 3 series Eaton posi. To set up a ring & pinion you must know how to set the pinion depth, bearing preload and backlash to get the correct contact pattern. If you don't get these right then the rear end will make noise and might not last very long. You will need a few special tools to do the job.
Old Mar 13, 2009 | 04:55 PM
danandamy's Avatar
Car: 86 Camaro
Re: Gears
If you're looking at various gear packages, you might note that some of the listings may read like 3:73 then 3:73thick. As stated above, you have the 2 series carrier, you'll have to have the "thick" gear to put 3:73's in.
Dan
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
