Is This Normal???
Old Jun 14, 2001 | 09:51 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is This Normal???
I just had my tranny rebuilt. I think the guy put in a manual valve body, because I can hold 1st gear at any rpm and downshift. But when shifting from 1-2 at high rpm it shifts but lags, it hangs at the rpm for a second and then drops a little, but on the 2-3 it shifts right away and there is a greater decrease in rpm. I am asking this because I just bought a G-Tech and ran it twice, the first time I spun thru 1st gear and with a friend in the car at 16.56 @ 86.7 mph, the second run with windows down and friend in the car 15.87 @ 92.9 mph, I figured the poor time is due to this lag in shifting from 1-2. Any ideas?
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jun 14, 2001 | 10:16 AM
whiterocz's Avatar
if your rpms rise then fall during a shift then your transmission is slipping. its just more noticable now that you have a shift kit cause before it wasnt shifting as fast. it has nothing to do with the valve body that is in there. your clutches are prolly wore out. might be rebuild time for you in the next few months.
Old Jun 15, 2001 | 01:36 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Suspect the band on this one. Also check your servo teflon o-rings.
Old Jun 15, 2001 | 08:10 AM
Car: 99 Formula
Axle/Gears: 342
I readjusted my TV cable, and the car seems to pull hard and shift better in first, but I haven't had a chance to G-Tech it, I am going away for the weekend, but will post results when I get back.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
