Axle Swap
Old Jun 15, 2001 | 04:57 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Axle Swap
How hard is it to do? How long will it take? I am putting my current 28 spline axles into a 26 spline rear end.
[This message has been edited by brodyscamaro (edited June 15, 2001).]
Old Jun 15, 2001 | 10:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
To change from 26 to 28 spline axles you need to replace the carrier for the ring gear. This means pulling the axles out, removing the carrier, changing the ring gear to a new carrier, probably having to get the ring and pinion setup again but not usually if all the spacers are put back where they came from.
The real difference between a 26 and 28 spline carrier is the side gears that the axles go into. You could pull the 26 spline side gears out and install some 28 spline ones. I tryed this on a 1986 26 spline carrier. My 28 spline aftermarket axles wouldn't go through the hole in the carrier. It needed to be drilled out to 1 1/16" for the axles to go through. I'm not sure how factory 28 spline axles would work but I'm guessing it would be the same.
If you don't already have a 28 spline carrier, you could buy the SLP takeoff or look for a 90 to present 10 bolt from an f-body or S-10/S-15 pickup. They will have 28 spline carriers and the 90-92 f-body will have the proper length axles.
Since you already have 28 spline axles, I assume you also have a 28 spline diff. Why not just swap the diffs?
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Oct 7, 2015 08:35 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
