700R4 FOR A V-6 VERSES 700R4 FOR A V-8
Old Jun 17, 2001 | 05:50 AM
MISS HOTROD's Avatar
:CONFUSED: I OWN A 1984 CAMARO Z28 WITH A 305/V-8 IN IT,I ALSO OWN A 1986 FIREBIRD WITH A V-6 IN IT,BOTH ARE AUTOMATICS.THE TRANSMISSION IN THE CAMARO IS FRIED. SOMEONE TOLD ME THE TRANSMISSION IN THE FIREBIRD WOULD WORK IN IT BEING THEY ARE BOTH 700R4'S BUT I WOULD HAVE TO DO SOME CONVERTING BEING IT IS COMING OUT OF A V-6 AND GOING INTO A V-8 (305). IF THIS CAN BE DONE CAN SOMEONE TELL ME PLEASE WHAT I WILL HAVE TO CONVERT TO MAKE THIS WORK? THANK-YOU-I MISS MY CAR!!!
Old Jun 17, 2001 | 09:11 AM
transfixleo's Avatar
They are two different trannies. For the work involved in pulling and trying to swap parts, etc. It would be easier (and beter) to get an '88 or later unit to start with.
Old Jun 17, 2001 | 09:17 AM
Jay 727's Avatar
It can work, I've done it before but in your situation it would not be cost effective.
The reasons are the differences, the transmission cases are different and the input drum too. Not a big deal just use your V-8 700R4 case and input but..the v-6 700R4 has less clutches in it meaning you would need to add the required amout for it to be able to handle the 305. Sure you could swap everything into the case as is and have a weaker trans but you would at least need a gasket and seal kit and both would need total disassembly, you might as well just get the bad one rebuilt, it will save you money in the end. A gasket and seal kit from TCI is $70, a cheap rebuild kit with clutches and all is $150, then figure the cost of labor. You're better off rebuilding the one.
Old Jun 17, 2001 | 11:49 AM
b92z28's Avatar
maybe im wrong but i could swear the 60 degree v 6 and the 90 degree v8 have different bell housings
92 z28 170,000 miles 14.20 on goodyear eagles before exhaust only mods k&n and slp 13/4 headers and dual 2 1/2 exhaust
87 trans am 12.20 on motor too many mods to list
Old Jun 17, 2001 | 01:00 PM
Not just the bell housing but the input shaft and converter too.
Old Jun 17, 2001 | 03:44 PM
Jay 727's Avatar
I like to refer to the bellhousing as a removable part, if it can't be removed I say case because you obviously have to change out the whole case if the bellhousing is not removable. If you go and tell the person the bellhousing needs to be changed it sounds simple until they go to change it. There would be a considerably different labor cost between changing a bellhousing( like on a ford c-4) and an entire case change out.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
