Positraction conversion?
Old Mar 16, 2009 | 04:11 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I have a 1990 RS 305 and it doesn't have a positraction rear end, but where I work we parted out a third-gen pontiac that had a disc brake rear end along with positraction, Besides replacing my whole rear end (i'm not down to spend all that money converting to discs in the back yet) can I use this rear end to make mine positraction, switch the gears over? anything? thanks in advance
Old Mar 16, 2009 | 04:16 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Positraction conversion?
Yes, but swapping complete rears actually may be easier and cheaper. Check the following link to better understand the situation (I'm assuming both rears are 10-bolts):
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 16, 2009 | 04:28 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
well i can get it the gears inside the diff for 40 bucks,
Old Mar 16, 2009 | 04:32 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
ohh okay, thanks for the link, the splines in the axle will make a difference, okay, well i the problem i have is i don't want to swap in the whole rear end because it had disc brakes, and mine is drum. Is it difficult/expensive to convert to discs? I need a bigger master cylinder and more brake lines (obviously) right?
Old Mar 16, 2009 | 04:41 PM
JamesC's Avatar
Why? It's a direct swap as I mention in the sticky above--you'll find all the info there that you'll need. For a street-driven car, I wouldn't worry about going to 26-spline axles.
JamesC
Old Mar 16, 2009 | 07:53 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Its not difficult to swap to disks. As james link says and ill say you can either go the route of an aftermarket adjustable proportioning valve or a stock disk/disk prop valve to replace your disk/drum prop valve. Just grab that valve off the jy car as well as the whole rear end and possibly even the speedo gears so that your speedo is still accurate. Its alot easier to just swap whole rear ends than mess with gears and such.
Old Mar 16, 2009 | 08:21 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i took a rear out of an 83 (i shattered my pinion gear and it blew out he side of my stocker) and totaly re built it, except for the gears they were perfect and the car i pulled had i 6X,XXX on the clock, anyway i went with an auburn pro serries LSD (possitrac) i was going to go eaton but i would of had to wait a few weeks, plus auburn has a 1 year replacement + a 4 year pro rated replacemnt, and nobody else offers the pro rated so i said what the heck.....anyway everything else is new in it and its great i went from 2.73 open to a 3.23 LSD, it really made a differance in take off and all around power, and still get good MPG's
as for the disk brakes i didnt want them, i want the car to appear 100% stock so i stuck with drums,so cant help you there but it looks like people have done that allready
Old Mar 16, 2009 | 10:04 PM
big gear head's Avatar
The reason that Auburn has that warranty is because they don't last long. Most people know that and their sales are suffering, so they offered the warranty. When the Auburn wears out (and it will) you can't rebuild it. That is why they offer the pro rated replacement.
kkingsrulee, If you have a '90 rear end then your drum brakes probably have the 4 bolt pattern on the backing plates. These brakes should bolt to the disc brake rear end. You could probably swap the rear end and put the drum brakes on it. This is assuming that both rear ends are the 10 bolt. There is a good chance that the Pontiac rear end is the 9 bolt and not the 10 bolt. In that case you will have to swap the complete rear end becasue the internal parts will not interchange. You can get a new Eaton posi and install in the rear end that you have, as long as the gears are 3.23 to 4.10. If not then you will have to change the gears too.
Old Mar 16, 2009 | 10:24 PM
89RS_82Z's Avatar
yea we will have to see, you remember i really wanted the eaton, but a $387 for the upgraded one and having it to me the next day i had to go with it
the guy who set up rear ends all the time said he has seen pleanty of auburns last a long time, he had one thing to say, that if you didnt used the fluid like the recomend it will not last long at all
if it goes out within the 5 years i will swap it, then sell the new one and put that toward the eaton
Old Mar 17, 2009 | 07:10 AM
JamesC's Avatar
The axle flange between disc and drum is shaped differently--at least in earlier years, so while you could mod the flange to go from drum to disc, going the other direction would require some fab work. Ed Miller sells a kit that makes the conversion a bolt-on, IIRC.
JamesC
Old Mar 17, 2009 | 10:02 AM
The later 7.5 rear ends had the same 4 bolt housng flange as the disc brake rear ends. The early rear ends had the 3 bolt flange and the later ones had the 4 bolt flange. If you have four 3/8 bolts holding the backing plates on then it's the same flange as the disc brakes. If you have the early drum brakes then you can get a set of drums off of a later S10 truck and put them on the disc brake rear end.
Old Mar 17, 2009 | 12:41 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
well if i wanted to just bolt on a completely new rear end that had the discs what would I have to do? don't link me to that page either. just add that proportioning valve?
Old Mar 17, 2009 | 01:33 PM
subroc's Avatar
Engine: 355 TPI
Add either a factory disk/disk prop valve from the car that your grabbing the rear end from or put in an adjustable prop valve. There is a very nice write-up on how to do that in the technical articles section of the homepage
https://www.thirdgen.org/propvalve
Its is how to install an Wilwood one but it will work for others as well ( i used a Stainless Steel Brake Corp valve). Its a bit more work doing an adjustable but you will get the most out of your brakes this way.
As far as what needs to be done to pull rearends:
unbolt panhard bar
unbolt lower control arms from rear end
unbolt shocks
unbolt torque arm from rear end
unbolt driveshaft
disconnect ebrake cables and brake cable at T junction
lower rear end down
(Also all this is to be done with the car securely on jackstands and the rear end supported)
Its fairly straightforward once you get under there. The only thing you will probably have to struggle with if your rear has never been out before is rusted bolts. If you do end up swapping rears...when u put the new one in anti-seize everything. It will make your life easier if you have to go in there again.
Old Mar 17, 2009 | 03:15 PM
JamesC's Avatar
Wouldn't think of it. Good luck.
JamesC
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
