just a little short?????
Old Jun 20, 2001 | 03:54 PM
88rscaamaro's Avatar
has anyone ever had this problem with there TC and the flywheel mine is about a 1/4 to 1/2 inch short why is that? and how can i fix it? my th700r4 is out of a 84 caprice how can i tell if it has a 27 or 30 spline input shaft? any help please????
1988 Camaro RS T-Tops white. Was 2.8 now a mean 406 sbc
(mods)
750 Edelbrock carb
Performer RPM intake
Comp cams Magnum @.50 230-230 lift 480-480
Flowtech 1 3/4 headders with glasspacks for true duals and thats it for now
E.T. 1/4=?
will post when race season starts
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
91-92 ground effects
Old Jun 20, 2001 | 07:17 PM
Jay 727's Avatar
You mean the gap between the converter and flexplate? I usually push the converter all the way in the trans and then pull it out about 1/8 inch, use washers to take up the remaining space before installing bolts.
Falcon50
Aug 22, 2020 03:26 PM
skinny z
Oct 5, 2015 06:23 PM
