tv cable
Old Mar 17, 2009 | 11:22 AM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
tv cable
with the kickdown cable disconnected on a tpi should the car still change gear, i take it it does'nt.
ive just fitted a different engine and box but waiting for the kickdown cable to arrive, i took it for a spin today with out the cable and it stayed in 1st would not shift i take it this is right
Old Mar 17, 2009 | 12:51 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: tv cable
Don't drive it this way, you will kill the trans! The TV cable does so much more than just kickdown. Running around without it, you have only around 50 psi line pressure, while normally you need around 200 at half-throttle. You don't always get that, but 50 psi at full throttle WILL kill the trans. I've been there, done that.
Old Mar 17, 2009 | 01:37 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
Re: tv cable
cheers, the cars off the road anyway i just went down the lane and back with it, ill get one on it asap then
Old Mar 17, 2009 | 01:40 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
Re: tv cable
should it change gear tho with out it?
Old Mar 17, 2009 | 02:16 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Re: tv cable
It can, but usually does a pretty crappy job if it does. From what I know the tv cable is the low tech method of the engine telling the trans what it is doing. It controls shifting a lot more than some people give it credit for. I remember when my tv cable was out of adjustment I could hardly get the thing to shift out of second without peddling the throttle.
Old Mar 17, 2009 | 02:46 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
Re: tv cable
ok should be alright then, it did not change out of first but the cables off all together so surely when its on it should make it change, im only woried as its a different box ive never seen work
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
