Manual valvebody question
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
Can you put a forward or reverse manual valve automatic in a street car?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As long as you remember that it's a manual valve body and you can start moving in any gear just like a manual transmission. Start driving around in third gear all the time and the tranny will quickly die.
The difference between a manual valve body and a manual shift kit is that the shift kit may still allow full automatic operation while left in drive.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
I recommend the Trans-Go Performance Shift kit. You still have the ability to manually shift transmission when in a race, but retain the full automatic features when normal driving. If you have any questions call me at 800 7763288 Mon-Sat 10-6 PST.
Glad Too Help!!!
Glad Too Help!!!
I second Pro Built on this. If you have ever driven a full manual on the street you know that it gets old quick, plus make absolutely sure that the shifter adjustment is PERFECT. I once had a guy with a full manual C-6 (Ford) toast in a couple of days. Upon inspection of the tranny I could find no cause for this. I checked the tranny once it was in the car and found that in the Man 1 and 2 positions the tranny and the shifter didn't agree and was dumping/crossleaking oil from one circuit to another. I adjusted it so it would be OK (I learned to HATE aftermarket shifters) and I never saw it again.
