Quick ?: Whats the diff between POSI and Zexel-Torsen differentials?
Old Jun 20, 2001 | 02:52 PM
92fire-audio's Avatar
I have a 92 firebird without posi rear end, SLP is selling take off Zexel-torsen differentials for $100, would it be a good upgrade over stock? Whats the difference between this one and the stock one or a posi one?
Thank you.
Old Jun 20, 2001 | 03:04 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
The Torsen differentials use all internal gears and do not have clutches like conventional posi units. This makes them able to transfer torque more accurately to each wheel and they will not wear out as quick as the posi units with clutches.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Jun 20, 2001 | 03:08 PM
Will these spin 2 wheels instead of 1 when i decide to step on it? It's embarrassing when people can only see 1 wheel spin..
Old Jun 20, 2001 | 11:25 PM
Both the Torsen and all other posi differentials are designed to transfer torque to both wheels. If you are only spinning one wheel then you have an open differential. Get the Torsen takeoff unit for $100 from SLP. It's a very strong and well designed piece.
Old Jun 21, 2001 | 05:24 AM
Great, thanks.. Hopefully this won't add too much cost to my ring and pinion installation (a guy around here is doing them for $200)..
Old Jun 21, 2001 | 05:44 AM
83_TA's Avatar
Where did you see them for $100.00 from SLP? I tried looking, but they are listed at $299.99..
'83 Trans Am
-Modified LG4 305
-Flowmaster 80 Series
-Holly HotShot air filter
-Edelbrock 1406 600cfm
-Performer Intake
-Sealed Power Cam
Plus many more.....
13.79 @ 105.64 Mph.
Old Jun 21, 2001 | 07:45 AM
That price is for the heavy duty Torsen differential. The normal duty version is available for $100. This is what all the LS1 F-Bodies come with standard (I'm pretty sure about this). I think the SS and the WS6 come with the heavy duty unit.
Old Jun 22, 2001 | 06:56 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Here's more info from the company itself:
http://www.torsen.com
Old Jun 22, 2001 | 10:51 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
<a href="http://www.slponline.com/view_product.asp?PARTNUMBER=64501T">SLP OEM
Zexel POSI</a>
Try that link.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC's
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
[This message has been edited by brharris27370 (edited June 22, 2001).]
junior419
Apr 7, 2025 11:35 AM
dbrochard
Jan 28, 2016 08:42 AM
Numbah-1
Sep 20, 2015 09:31 AM
carattini
Sep 10, 2015 07:46 AM
toyotekk
Sep 6, 2015 02:21 PM
