T56 6SPD DRIVESHAFT LENGTH?
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
I KNOW EVERYONE HERE IS GOING TO TELL ME THAT YOU CAN USE AN AUTO/D OUT OF A THIRDGEN FOR MY T56 SWAP. THE T56 D-LINE IS SHORTER HOUGH. BY HOW MUCH? IT SOUND TO ME LIKE YOU WOULD HAVE TO SHORTEN THE AUTO D-LINE.
HOW ABOUT SOME GOOD TECH ANSWERS. ANYONE?
THANKS, MAN
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
THANKS, MAN
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Please dont type in all caps.
And no you dont have to shorten your driveshaft. The automatic and manuals use the same driveshaft, whether its a 700R4, 4L60, 4L60E, T5, or T56. They're all the same length driveshaft.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
When I bought my driveshaft from Denny's DS, they had me measure the distance from the top flat surface of the rear yoke to the top flat surface of the tailshaft housing.
With the TH700-R4 this was 44-11/16".
When I got done swapping in my T56 I re-did the measurement and got 44-6/16"...the T56 is 5/16" longer than the 700.
I called Denny's and reviewed this with him, he indicates the DS length is no problem. My DS is 0.50" longer than a 4th gen aluminum DS, so definitely no issue if you're talking about reusing the stock piece.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
-Kevin
1982 Z-28
bigjay89gta
Oct 15, 2015 08:04 AM
