trans doesn't want to downshift out of drive?
Old Jun 25, 2001 | 01:52 PM
oneslowV8camaro's Avatar
I new here and need a little help. When driving my car(82 berlinetta 305) and I get into drive(its a 200c by the way) and I slow down for a corner it doesn't want to downshift out of drive unless the engine drops down to around 400rpms or about 25-30mph. What could cause this, is it the TV cable or is something else wrong?
</p>
Old Jun 26, 2001 | 09:24 AM
Comeon guys I need help, is this a major problem or what. Also it doesn't do it when on the 2-1 downshift so i'm wondering what the problem is. It also upshifts fine so what could it be. Please help!</p>
Old Jun 26, 2001 | 09:54 AM
82camaro's Avatar
Car: 82 camaro SC
Try the cable, not many people here know alot about the th200c. How are the upshifts at WOT?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
BlueIroc-Z
Jun 9, 2019 03:22 AM
maroe624
Apr 16, 2017 08:29 AM
jharrison5
Aug 19, 2015 05:53 PM
zeitghaist
Aug 18, 2015 07:33 AM
mizz0313
Aug 12, 2015 06:45 AM
