700r4 has gotten even worse. HELP PLEASE
Old Jun 20, 2001 | 01:31 PM
IROC-JP's Avatar
Last night, when I shifted from 1st to 2nd there was a loud clunk, and I had lost 2nd completely. Now when I tried to test it this morning I don't have reverse anymore either. However, I still have 1st, and think I still
have 3rd.
What did I break? This is my everyday driver so I really need some help.
-Jason
'86 305 TPI 700R4
Edelbrock headers, highflow cat, borla cat-back exhaust, AFPR, modified MAF, ported plenum,
Stage 2 chip, 1.6 ratio roller tip rockers, b&m megashifter, Transgo shift kit, MSD 6AL
Old Jun 20, 2001 | 01:32 PM
IROC-JP's Avatar
In addition there seems to be a low whining noise coming from the tranny.
Old Jun 20, 2001 | 02:38 PM
IROC-JP's Avatar
The whining occurs only in park, reverse, and neutral and it gets louder when I increase the rpms. 1st and 3rd definitely still work, I'm not sure about 4th yet though. When I shift from drive to reverse I can feel the tranny shifting like usual, but when I get on the gas it is like being in neutral.
Old Jun 20, 2001 | 02:43 PM
Pro Built Automatics's Avatar
You have broke the sun shell in the rear portion of the transmission, time for a rebuild.
Old Jun 20, 2001 | 03:04 PM
transfixleo's Avatar
As Pro Built said, your Sun Shell is broken. This is very common. Make sure that the shop installs the newest version from the dealer and not some used piece from a core.
Old Jun 20, 2001 | 03:07 PM
IROC-JP's Avatar
What exactly is the sun shell? Is this in the rear housing? Or is it deep inside the tranny? How much do you guys think a shop would charge?
'86 305 TPI 700R4
Old Jun 20, 2001 | 05:18 PM
IROC-JP's Avatar
I see what the reaction sun shell is from my tranny repair manual. How did this break though, was it just because it was old?
Old Jun 20, 2001 | 07:03 PM
IROC-JP's Avatar
The tranny is an '88 and I'm not sure what car it is out of. Did it bust because it wasn't strong enough as a 700r4 out of a camaro.
Old Jun 20, 2001 | 09:50 PM
KED85's Avatar
It was time.
Rebuild the entire tranny.
You are looking about about $1,000 - $1,700 rebuild price.
Join the club.
Mine went, too.
I only have a 3.4 V-6.
And I have to pass smog with only 1-2 maybe 3 of my 700R4 (if I get lucky with probuilt autos tips THANKS).
Many places will do it within a day.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 21, 2001 | 01:39 PM
Camaro_hunter_d's Avatar
look into a aftermarket one.. for 1100 you can get a pretty damn god one...
Old Jun 22, 2001 | 12:20 AM
IROC-JP's Avatar
I just opened up the tranny and sure enough the sun shell is broken. The band looks good and so do all of the clutch packs.
How can I be sure that I won't just break the new one that I put. I think this tranny is out of an '88 Caprice, it should be able to handle 305tpi or is this what broke it?
'86 305 TPI 700R4
Old Jun 22, 2001 | 04:20 AM
This is a common problem on these. You could call it a bread and butter job for tranny shops. To prevent this, go to the dealer and buy a brand new one. Most shops just grab another one from a core and send it on it's way. GM has redesigned the radius a couple of times and seems to have it down now.
This is also why I harp on people about jumping onto the Huge Servo/Boost Valve bandwagon looking for the hardest 1-2 shift they can get. As KED85 found out, even V-6's do this. what do you expect when you have a strong small block and tire chirping shifts?
Old Jun 24, 2001 | 09:12 PM
IROC-JP's Avatar
Thanks. That makes sense since it broke when the tranny shifted from 1st to 2nd. I just got a new one from gm and now I'm looking at the band and clutch packs. They all seem to have a lot of material left, and I don't see any blacks they all look kind of like a brown color.
However, on one of my overrun clutches almost all the friction material broke off, so there is chunks of it all over in the input housing. Did this happen because the tranny had been sitting for probably over a year, and maybe the clutch was dry and got stuck?
'86 305 TPI 700R4
Old Jun 25, 2001 | 03:46 AM
Whenever I see friction material come off of a clutch I suspect a bad radiator. It breaks down the bonding on the steel backer.
Old Jun 25, 2001 | 12:15 PM
IROC-JP's Avatar
What do you mean by a bad radiator?
My current radiator is only about 2 years old and looks to be in good condition from the outside.
-Jason
'86 305 TPI 700R4
Old Jun 26, 2001 | 04:28 AM
The tranny cooler is inside of the radiator and if there is a leak the water/antifreeze mix will attack the bonding of the friction material. I'm not saying this is what happened, just that it has to be considered.
Old Jun 26, 2001 | 07:50 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You would be able to tell as antifreeze/water would turn the fluid an opaque pink color instead of transparent red.
Old Jun 26, 2001 | 12:02 PM
IROC-JP's Avatar
Nope, the tranny fluid still looks deep red.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
