th400 trans problems
Old Mar 21, 2009 | 12:41 PM
transam360's Avatar
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
Ok here is what is going on I have a mild built 468bbc about 625hp I took it out a few times shifted fine then I took it out a week later got on it a few times shifted fine then I got on it one more time and I shifted 1st 2nd then I went to go into 3rd and it did not feel like it shifted and the rpms stayed at 6000rpm then I slowed down and got back into it and it felt like it shifted but it still was not going anywhere and rpms stayed at 6000. Heres the things I have tryed already yes the shift linkage is right the fluid is at the right level and the fluid still looks brand new very clean nice and red but I did just put the fluid in a month ago and drove the car 10 miles at most if that helps. Is the trans gone?????
Old Mar 23, 2009 | 03:50 PM
Shagwell's Avatar
Car: projects.......
Re: th400 trans problems
Sounds like you hurt the direct clutch pack. Fairly comon in a stock th400 or one that was not built correctly.
Old Mar 24, 2009 | 05:18 PM
transam360's Avatar
well just went out yesterday and bought a coan th400 trans so as soon as i get the old one out i am going to take it apart and see what went wrong
Old Apr 5, 2009 | 10:17 PM
gmpptech's Avatar
The direct clutch accumulator in the valvebody likes to crack and bleed off pressure, replace the plastic with a alluminum one.
Old Apr 5, 2009 | 10:19 PM
gmpptech's Avatar
http://www.makcotransmissionparts.co...-400servo.html
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
