Converting rear to disc from drum
Old Mar 21, 2009 | 06:00 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
How many parts am i going to have to change to convert from rear drums to disc?
88 camaro(standard)
Old Mar 21, 2009 | 08:17 PM
big gear head's Avatar
Re: Converting rear to disc from drum
Do you have 3 or 4 bolts in the backing plates? If you have 4 bolts then all you need is a complete disc brake set from another rear end. If you have 3 bolts in the backing plates then you are going to need to do some modifications to the housing ends.
Old Mar 21, 2009 | 08:22 PM
chevman24's Avatar
So i wont need a new brake proportioning valve or anything like that? Ive done the brakes and im sure its a 4 bolt unit.
Old Mar 21, 2009 | 08:42 PM
You will probably need the proportioning valve. I don't know much about that part. I just know that the housing ends are not all the same. The disc brake rear ends and later drum rear ends use the 4 bolt flange and the early drum rear ends use the 3 bolt flange.
Old Mar 21, 2009 | 08:50 PM
chevman24's Avatar
thanks
Old Mar 21, 2009 | 08:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Covered in the sticky:
https://www.thirdgen.org/forums/tran...-10-bolts.html
By the way, chevman or big gear, note the drum flange (from a 91 'Bird) in the following link (I haven't seen all drum brake rears, but the one in the link is the only one I'm familiar with):
https://www.thirdgen.org/ls1reardisc
JamesC
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
