SPEEDO's drive gear keeps coming off output shaft what so i do?
Old Jun 26, 2001 | 10:19 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I recently replaced my 2.77 rear with a 3.73 rear and i performed the speedo gear change. My problem is while driving the electronic speedo stops showing speed & when i took off the tail section of the trans the Gry drive gear part #(8642620) slides all the way forward in the trans and yes i made sure i had the gears lined up properly. Ive replaced the gry drive gear( 8642620) & the Lt. blue 45 tooth part #(25513052) twice! Are these 2 gears designed to work togeher or what? The small metal clip was installed booth times & the second time i made sure that it was locked in place but the gear after a few miles still moved out of place. If u guys think that two gears are wrong for each other please let me know asap! Also dont forget , I have the electronic speedo.
thanx
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
beachrodder
Aug 7, 2015 04:27 PM
MENINBLK
Aug 5, 2015 11:58 PM
