27 or 30 spline????
Old Jun 22, 2001 | 02:45 PM
88rscaamaro's Avatar
27 or 30 spline????
how can you tell the differnece between the two and what would happen if you were to put a 30 spline TC on 27 spline tranny??? or the other way around???
1988 Camaro RS T-Tops white. Was 2.8 now a mean 406 sbc
(mods)
750 Edelbrock carb
Performer RPM intake
Comp cams Magnum @.50 230-230 lift 480-480
Flowtech 1 3/4 headders with glasspacks for true duals and thats it for now
E.T. 1/4=?
will post when race season starts
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
91-92 ground effects
Old Jun 22, 2001 | 05:38 PM
Pro Built Automatics's Avatar
the 27 spline will not fit the 30, and the if the 30 is installed on the 27 the car will not move. If yours is a genuine 1988 you have the 30 spline.
Hope This Helps!!!
Old Jun 22, 2001 | 09:12 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
What does an 87 iroc have
1987 BLUE IROC
IT'S A DOG
BUT IT'S MY DOG
AND IT HAS A NASTY BITE......
CNYFBA MEMBER
http://cnyfba.cz28.com/
Old Jun 23, 2001 | 02:17 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
30 spline. The 27 to 30 spline change happened in late 84. Early 1984 cars have the 27 spline 700R4 trans, while the later ones were switched to 30 spline.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 23, 2001 | 05:36 AM
the car is a 88 but the tranny is out of a 84 caprice since mine was a v6 and now a v8 i needed a new tranny. is there any number to tell kinda like on a motor block???
(mods)
750 Edelbrock carb
E.T. 1/4=?
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
Old Jun 27, 2001 | 09:03 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Unless you are good at decoding (some trans have date codes, other don't), the only true way is to pull the trans and remove the TQ conv. Then you can count the spline and be sure of it.
George P. Lara
1984 Z28
SCCA, SCFB, SC3GFB
codeysabatini
Nov 10, 2015 04:07 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Numbah-1
Sep 20, 2015 09:31 AM
Prodigious
Sep 18, 2015 05:23 AM
