What size flexplate???
Old Mar 22, 2009 | 02:12 PM
1987-iroc-z383's Avatar
Car: 1987 chevrolet camaro Iroc-z
Engine: 383 tpi
Transmission: built 700r4
Axle/Gears: posi 3:45
I have an internally balanced 383 and need to know which size 10.75 or 11.5 inch flexplate i need. I found one on summit from quicktime that is 153 teeth for a 6.6(400) neutral balance engine and it gives me the option of either the 10.75 or the 11.5 inch, and Im not sure which I need for my application. 700r-4 and most likely mini-torque starter.
Old Mar 22, 2009 | 02:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What size flexplate???
It's always preferable to go with a 168 tooth ring gear.
Providing your internally balanced 383 is a 2 piece rear main seal block, any standard 168 tooth ring gear for a 350 engine will do fine.
Old Mar 22, 2009 | 03:59 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I'm truly curious why 168 tooth is better? I have been preferring 153 tooth.
Old Mar 22, 2009 | 04:03 PM
Engine: 383 tpi
Its the 3970010(68-80) or w/e block which I believe is a 2 piece rear main. I was under the impression that you need a 400 flexplate for the 383 as it uses the 400 size crank?
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
