trans pan removal
Old Mar 22, 2009 | 04:10 PM
leek157's Avatar
Car: 95 SHO. 87 IROC red 69 Vette blue
Engine: 3.0 Yamahammer.5.7 TPI L98, 350
Transmission: mtx4 ,700r4, 4speed,
Axle/Gears: 3.27, 3.73
trans pan removal
is there an easy way to get to the last few bolts on the trans pan on a 700r4 that are under the crossmember or do i have to remove the crossmember
Old Mar 22, 2009 | 07:11 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: trans pan removal
It is possible to get a ratchet/extension/socket or wrench on every one of them, but it's easier to just put a jack under the torque arm mount and drop the crossmember. Then you're gonna make a big mess, unless your pan already has a drain plug. If not, it's $6 well spent.
Old Mar 22, 2009 | 07:20 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
before i put my derale pan on mine i used to take out everybolt but the back ones that are a pita, then i would take them out just a little bit with a box end wrench to let the pan tilt down and drain more in the front of the pan, when it stops draining let the bolts out little by little....... hold the pan when they are almost out and finish taking them out, then tip the pan over in the drain pail you are using.....i also recomend why you are down there an energy tq arm bushing and a energy trans mount
Old Mar 22, 2009 | 11:07 PM
leek157's Avatar
cool thanks for the help
maroe624
Apr 16, 2017 08:29 AM
gta power
Aug 13, 2015 06:15 AM
mizz0313
Aug 12, 2015 06:45 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
