trans. cooler install
Old Jun 26, 2001 | 11:45 PM
3504mula's Avatar
Car: 90 Formula
I will soon be putting a shift kit and higher stall converter in my 700 and I was wondering if anyone has any pictures of an installed cooler and directions on how to do it.
Thanks a lot.
1990 Formula 350
*Hooker Headers
*Random Technology 3" Exhaust(no cat)
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
*Metco Lower Control Arms
w/ Lowering brackets
*F-Body Perf. Panhard Rod and Strut Tower Brace
*1999 16x8 Formula Wheels
*White Face Gauge Overlays
Old Jun 27, 2001 | 10:52 AM
91L98's Avatar
Install it right on the a/c condensor. It will fit fine between the condensor and the cross braces. The straps that are included in most kits will hold it in place just fine. I installed mine right in front of the fan so that air is pulled through it when the fan is on. Very easy job. Check fluid level after and if it shifts funny, reset tv cable.
Old Jun 27, 2001 | 03:48 PM
86SCBNJ's Avatar
If you are going to install your cooler in front of the A/C condenser, here are some tips. Remove the plastic hood latch cover. Be careful not to rip the plastic clips. Remove the cross bracing, two bolts for each. This will give you enough working room to mount your cooler...
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Suspension Techniques Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with Toyo 245's. For autocross, 16" IROC's w/bfg R1's... Nothing easy can be fun...
Old Jun 27, 2001 | 04:59 PM
Tom Keliher's Avatar
If you buy a trans cooler kit, it will come with the hoses; hardware; and instructions on how to install it. The location is up to you. Here is a typical installation. I also added a remote spin on filter for the trans:
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
84z96L31vortec
Aug 20, 2017 12:16 AM
toronto formula
Nov 10, 2015 06:17 AM
Hello, Michael
Aug 20, 2015 03:19 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
rsrmoore
Aug 7, 2015 08:44 PM
