When swapping gears to 3.73 what speedo gears part # to use?
Old Jun 28, 2001 | 09:34 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I'm going to swap electronic speedo gears for my 86 tpi & i need The part # for the 2 gears that match each other & can be used for the 3.73 ratio changed.16 inch rims 245 50 16 tires.
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Old Jun 28, 2001 | 11:38 PM
Omar's Avatar
Using 245/50/16 with 3.73's
Cable Driven:
15T Gray Drive Gear (8642620)
45T Lt Blue Driven Gear (9775187)
Electronic Driven:
45T Lt Blue Driven Gear (25513052)
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jun 29, 2001 | 03:19 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your 86 Trans Am should be electronic driven, in case that was your next question.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 29, 2001 | 07:40 AM
86Tra/maro's Avatar
thanks ,but the gear on the output shaft keeps sliding foward on me what should i do?
Old Jun 29, 2001 | 09:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I read an earlier post by you, and I know you said you installed the clip, but the gear should fit so tight, that you really don't need the clip. The gear has to be tapped on the output shaft. If it slides easily, either the shaft or the gear isn't right. Check this out: Speedo gear swap
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
hectre13
Dec 11, 2023 08:14 AM
Jorlain
Aug 24, 2022 05:11 PM
draco
Oct 4, 2015 09:25 PM
InfinityShade
Aug 22, 2015 08:00 PM
1nastygta
Aug 8, 2015 07:38 PM
