PROPER SPEEDO GEAR FOR 3:73 REAR END
Old Mar 25, 2009 | 11:38 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
Hi! Does anyone know which speedo gear is to be used for a 1988 Trans Am with 3:73 gears. The car has a 700r4 trans, and stock 245/50/16 tires. I know the gears are color coded, and it depends on the number of teeth. Any idea?
Old Mar 26, 2009 | 01:16 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: PROPER SPEEDO GEAR FOR 3:73 REAR END
15 tooth drive and 45 tooth driven.
Old Mar 26, 2009 | 06:13 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Actually, you need a 44 tooth driven. The drive gear is gray, part number 8642620, and the driven gear is Dark Gray, part number 9780470 for non-digital dash, or part number 25513051 for digital dash.
Old Mar 26, 2009 | 02:48 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
I have the digital dash so I need to get a driven gear #25513051, and drive gear #8642620. Thanks!
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
