T56 vibration
Old Mar 26, 2009 | 09:58 AM
TMZIrocZ350's Avatar
Car: 89 IROC
Engine: 5.7L
Axle/Gears: 3.70
T56 vibration
I put a T56 from a 95 trans am with about 90K on it into my camaro and I'm still trying to debug a couple of issues. My largest issue is a vibration in 5th and 6th gear. The car rips through 4th gear and then when shifted into 5th and still hard on the gas the car begins to shake a little and you can hear and feel a difference in the transmission. It feels like something is rubbing inside the transmission. When in 6th and cruising at highway speed the transmission gives off a harmonic vibration which goes away slightly when going faster than 80.
I am thinking the trans is in need of a rebuild, but am not exactly sure what is wrong with it. The syncros are still in good shape. I do get a clunk shifting into second, but not horrible. I was thinking that maybe that some of the gears inside are a little messed up or a bad bearing.
I have some rear diff issues as well, but I ruled that out because 1st through 4th are fine and it only happens in OD. I also have an aluminum driveshaft I am going to try, but it doesn't fit because of the stupid Spohn loop. I think the loop is getting cut off soon and will put the aluminum DS in.
I am kind of stuck right now with this transmission and would like to get all the problems ironed out before prime cruising season gets here.
Old Mar 26, 2009 | 03:01 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T56 vibration
Did I already see this on another board?
5/6/R are on an extension shaft on the back of the trans. Any number of things (none good) could go on back there..
mike
Old Oct 18, 2009 | 08:33 AM
t56's Avatar
t56
Re: T56 vibration
I am having the same problems. Have you found out what is was???
Angelo
Old Oct 18, 2009 | 09:05 AM
85MikeTPI's Avatar
Re: T56 vibration
5 and 6 are overdrive gears, and put alot of load on the engine & clutch. Usually when a clutch starts to fail, it will show up in 5th and 6th as the clutch slips and chatters, not being able to hold the TQ between engine and trans..
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
