Transmission chirps when clutch not depressed
Old Nov 27, 2000 | 07:25 AM
Milt90rs's Avatar
I have a 1990 manual transmission that chirps when the clutch is not depressed, in neutral or in gear. But when I depress the clutch slightly, the chirp disapears. Any ideas on what needs to be adjusted and how would be appreciated
Old Jul 2, 2001 | 03:40 PM
lordlexus's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Milt90rs:
I have a 1990 manual transmission that chirps when the clutch is not depressed, in neutral or in gear. But when I depress the clutch slightly, the chirp disapears. Any ideas on what needs to be adjusted and how would be appreciated</font>
I have this exact same problem. Can't figure it out for the life of me. It seems to just go away when you slightly touch the clutch pedal....ANY ONE HELP!!
Old Jul 2, 2001 | 10:14 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I believe your through out bearing is starting to fail. The chirping is the bearing making noise under light load. replace the through out bearing to eliminate the load.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
