Gear Question
Old Mar 27, 2009 | 03:25 AM
Camarokid08731's Avatar
Gear Question
i had an 89 camaro rs with a 2.8 then i bought a 91 rs with a 5.0 automatic. i took the rear out of the 2.8 wich has a 3.42 gear ratio. my 91 had a 2.73 ratio and now my speedos way off. wich speed sensor do i get to fix this?
Old Mar 27, 2009 | 03:49 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: Gear Question
Do a search on Speedo gears, all the info you need will be there...
Old Mar 27, 2009 | 09:13 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Gear Question
Yes, the info is there, but the short answer is: go down to your local GM stealership, and order a part number 8640517 and a 25513052.
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
