My friend keeps beating me help!!
Old Jul 2, 2001 | 02:02 PM
blackbelt's Avatar
Right now I have a stock 91 Camaro 305, 5 speed with 3.08 rear end ratio no posi. My friend has a 89 Camaro 305, 5 speed and 3.08 rear end ratio but he has posi. His is bone stock too but he always seems to be able to beat me of the line and all the way for that matter. What is the easiest and cheapest eay to add posi. and what rear end ratio should I get 3.27 or 3.42 or just stay with 3.08 Please tell me what are prices and where to get the stuff if you recomend something. Thanks all.
Old Jul 2, 2001 | 08:45 PM
Jza's Avatar
Jza
<font face="Verdana, Arial" size="2">cheapest and easiest...</font>
OEM take-off posi from SLP. $79 - $99 depending on if you catch them during a special.
Powertrax is supposedly the easiest to install, but at $400?
Old Jul 3, 2001 | 01:41 AM
ws6formula89's Avatar
Well, one other explanation I could give is....he could have shorter tires than you, that would give him a smaller final effective ratio, and better take off. Is his car what? What do you have? 305 what? I agree the SLP is really awesome, I like it better than my former Auburn set. You could just have a tired engine, or tall tires. You would be surprised in how much a difference in tire profiles can do for your acceleration, I know someone that put 2 profile sizes lower on his 79 s-l-a-n-t 6 Volare wagon, and the acceleration was very excellent. He took a 93 Cutlass Convertable and he wasn't even trying to race! His speedo was off about 10 miles per hour though.
-ws6formula-
1989 Pontiac Formula WS6
69,000 miles.
305 TBI, 4.10 gears, SLP Zexel/Torsen Limited Slip Differential, 700r4 Corvette Servo, LT4 Hot Cam/Valvesprings, GM Aluminum Driveshaft, 2700 RPM Stall, Edelbrock Performer RPM intake manifold, Turbocity TB. Ran on 6-19-2001 again: UPDATED: 14.1 @ 97.68 mph. Dyno'd Bone Stock @ 172.6 rwhp, 266 ft-lbs. of rw-torque.
[This message has been edited by ws6formula89 (edited July 02, 2001).]
Old Jul 3, 2001 | 08:11 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Do some of the free mods like advancing your timing a few degrees.Do u have TB or TPI? Your first "purchased"mod should be your exhaust system & a good air K&N air filter. U will definitly like the seat of the pants feel!
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Old Jul 3, 2001 | 11:24 AM
Blown 87 camaro's Avatar
Word of advice....... get auburn posi about 350 dollars.. and a set of 3.73 gears..and rememeber you can take 2 tenths off for free!!! its called wieght.. seats,carpeting,plastic panels.
COdy
Wieand blown 87 camaro
Old Jul 3, 2001 | 02:08 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
get a posi and improve your traction.. also get a k+N and do some exhaust work ..
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear, lt1 cam , 350 heads
Lbibb
May 5, 2016 12:00 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
sandman92084
Sep 12, 2015 10:27 PM
