moser 9" ?'s
Old Mar 28, 2009 | 04:06 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
moser 9" ?'s
i have a moser 9" with the alum thru bolted center and 3.89's my question is does this swap require a diff drive shaft? i have my stock one installed and i have a vibration during hard acceleration and highway speeds! i have new u joints. everything is tight except at the yoke where the driveshaft enters the trany you can grab it and wigle it around about a 1/16 of an inch, just enough that you can see a gap in the seal. i think the ds is to short now it has about 1.5 inches showing with weight on the axle
Old Mar 28, 2009 | 04:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: moser 9" ?'s
im using a stock length shaft with the same rear and i have no issues, but im running a tko600 manual trans, but its supposed to be the same length as a 700r4/t5
If the rear is centered front to back in the car, and you have 1.5" of the yoke sticking out out of the trans, you need a new driveshaft.
Old Mar 28, 2009 | 06:33 PM
big gear head's Avatar
Re: moser 9" ?'s
If you are using the same drive shaft that you had with the 7.5 then it is too short. Which yoke do you have on the 9 inch? If it's a truck yoke then it will be much shorter than the 7.5 was. The car yokes are a little longer, but still not quite long enough.
Old Mar 28, 2009 | 06:45 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: moser 9" ?'s
im not sure if its car or truck. its a moser thru bolted aluminum center section
though. i did reuse the drive shaft
Old Mar 28, 2009 | 06:48 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: moser 9" ?'s
Old Mar 28, 2009 | 07:03 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: moser 9" ?'s
Try unbolting the driveshaft from the rear and sliding the yoke in more and see if you still have that problem with the wiggle. Mine is out about a inch and i have no wiggle, it's good and tight.
Old Mar 28, 2009 | 09:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: moser 9" ?'s
Proper length is to slide the yoke into the tranny all the way then pull it back out 1". If the u-joint isn't in the diff yoke at that point then the driveshaft is too short or you need a longer diff yoke.
Old Mar 30, 2009 | 01:40 PM
Shagwell's Avatar
Car: projects.......
Re: moser 9" ?'s
If you are making enough power to need to upgrade rear ends, then you should be upgrading the driveshaft anyway.
Old Mar 30, 2009 | 02:46 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: moser 9" ?'s
if you use the factory driveshaft you need to change the u-joint to a 1350 on one side and a 1310 on the other you can use the same drive shaft i have the same rearend and gears
Old Mar 30, 2009 | 06:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: moser 9" ?'s
Third gen yokes are not 1310. They're called 3R. Close but not exactly the same.
Old Apr 1, 2009 | 11:24 AM
tom86iroc's Avatar
Car: 1986 iroc
Re: moser 9" ?'s
didn't know that but you can't a 1350 to 3r ujoint but they do make the 1310 to 1350 conversion joint
Old Apr 2, 2009 | 11:56 AM
Re: moser 9" ?'s
That is the short truck yoke, and it's probably a 1350. I recommend that you get a new driveshaft made with 1350 yokes on both ends. Contact the drive shaft manufacturer that you are going to use and ask them how they want the mesurements made. Not all manufacturers use the same measurements. Inland Empire Drive Line is a good one. iedls.com
darwinprice
17
Oct 11, 2015 11:51 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Nick McCardle
Sep 10, 2015 08:36 PM
