How to set backlash
Old Jul 9, 2001 | 06:47 PM
Black82Z's Avatar
How to set backlash
i'm about to place a zexel torsen diff in a 95 rearend that is going into my 82z, it is an open diff 3.42 rear. I would like to know how to set the backlash on the gearset, Is it the back and forth movement in the case??? or do i even need to set the backlash, i am just switching the diff carrier that is all, i am using the same gears and am not taking out the pinion. please help
Old Jul 9, 2001 | 07:47 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You need to swap carrier shims from side to side to move the ring gear further or closer to the pinion. Check this out: 10 bolt
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
