Inspecting junkyard transmissions
Old Apr 1, 2009 | 11:15 AM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
I will be scouring my local junkyard for a decent T5 transmission this weekend. Never having opened a transmission case i was hoping for some direction. What should i be looking for? Is synco wear visible? What are some telltale signs the transmission is on its way out?
-Z
Old Apr 1, 2009 | 03:31 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Inspecting junkyard transmissions
Synchro wear isn't visible, and getting the top panel of a T5 off in a junkyard would be a feat in-itself.
Depending on what you have access to in the junkyard, the best you can hope for is to check if each gear can be engaged by the shifter, and possibly if the input/output shafts are seized, and maybe if no gears are stripped by turning the input in each gear, and holding the output for a full turn to feel it's resistance.
Old Apr 1, 2009 | 06:40 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
check the fluid condition too. If its black and smells burnt, stay away.
armybyrd
Sep 28, 2023 12:16 AM
Lbibb
May 5, 2016 12:00 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bjpotter
Oct 4, 2015 07:48 PM
Damon
Sep 26, 2015 04:29 PM
