Posi Rearend Help!!!!!!
Old Jul 9, 2001 | 10:51 PM
Sincat_23's Avatar
I changed the diferental fluid in both my 92 RS(open rearend) and my 95 Z28(posi) yesterday. The 95 is making noises now but the 92 is not. I put Posi additive in the 95. It only has 44,000 on the car. Could it be low on fluid or what? It was quiet before I changed the fluid and now it kind of makes a clanking noise. Please Help! Thanks
92 Camaro 3.1 V6 (Red)
-Hypertech Chip
-Dynomax Exhaust
-Taylor Spiral Spark Plug Wires
-2.5 Harwood Lift-Off Cowl Hood
-B&M Megashifter
-B&M Shift Improver
-15x8 Crager 5-Star Chrome Rims
-Yellow Weapons-R Intake Filter
-Custom Cold Air Intake
-KYB Shocks & Struts
-Borla Exhaust Tips
-MSD Coil
-Air Lift 1000 Load Assist Springs
-EnergySuspension Swaybar Bushings and Links
-ACDelco Rapid Fire Plugs
Old Jul 10, 2001 | 07:15 AM
purpleworm's Avatar
What kind of additive did you use?
Old Jul 10, 2001 | 07:52 AM
82camaro's Avatar
Car: 82 camaro SC
I hope you filled it to the top when you changed it and then checked it when you heard any noise. Did you add enough additive?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
