converting axles and carrier from disc to drum
Subscribe
Apr 2, 2009 | 08:55 PM
Im looking at buying a rear axle that is disc instead of drums. its just the housing, backing plates, caliper brackets, and calipers. I have an 85 camaro with a 10bolt and drum. is there anything special i need to do or can i sawp the axles and carrier over? thanks
Reply 0
Apr 3, 2009 | 07:24 AM
Re: converting axles and carrier from disc to drum
Quote: Im looking at buying a rear axle that is disc instead of drums. its just the housing, backing plates, caliper brackets, and calipers. I have an 85 camaro with a 10bolt and drum. is there anything special i need to do or can i sawp the axles and carrier over? thanks
Sorry, I'm not entirely sure what your intensions are, so what I have to say may be off base. The axle flange on the drum rear is different that a disc rear, so you would need to mod that flange or purchase a bolt-on type backing plate from Ed Miller to adopt rear discs. There's also the e-brake issue.
JamesC
Reply 0
Apr 3, 2009 | 07:39 AM
I believe your talking about a rear end not the axle. And yes you will probably have to redo the proportioning valve.
Reply 0
Apr 3, 2009 | 07:45 AM
If 84 is correct, you'll need to swap the proportioning valve for best brake performance (the master will be fine), you'll need e-brake cables, and if the new rear is a different ratio, you'll need to swap the drive and/or driven gears to make the speedo read correctly.
There's info in the following sticky that may be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Reply 0
Apr 3, 2009 | 08:06 PM
sorry i didnt make my question easier. i have a 85 camaro with a 10 bolt posi and drum brake. im lookinbg at buying an axle housing with calipers, it doesnt have axles or diff, will my current axles and posi be a direct fit?
Reply 0
Apr 4, 2009 | 10:31 AM
Quote: i have a 85 camaro with a 10 bolt posi and drum brake. im lookinbg at buying an axle housing with calipers, it doesnt have axles or diff, will my current axles and posi be a direct fit?
Yes, with the proper rotors. Check post #13 in the following link:
https://www.thirdgen.org/forums/brak...drum-rear.html
Your posi should swap in with no problems.
JamesC
Reply 0
Subscribe
