Need info ASAP with auto to t-5 swap!
Old Apr 4, 2009 | 08:18 AM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
i have a 87 iroc 350 tpi
im takeing the 700r4 out of it and putting a t-5 in.
all parts are coming off a 87 firebird 305 carb
what im needing to know is their are 2 different part numbers for flywheels. one for carb and one for fuel injection.
But diameter and teeth number is identical.
will the carb flywheel off the bird fit on my fuel ijection car?
the crank part #'s are both the same for carb and fuel injection, so the crank is the same.
and the clutch kit is the same part number for fuel injection and carb.
even the rear main seal is both same part number and 1 peice.
what gives?
is their something im missing here.
Old Apr 4, 2009 | 09:54 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Need info ASAP with auto to t-5 swap!
so long as you get a flywheel that has the same rear main seal design as your crank, that you will be fine. The is no difference between a carb flywheel and a fuel injected flywheel that i know of. Maybe weight? are their any specs of the wheels you are looking at that you can compare?
Old Apr 4, 2009 | 01:44 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I already answered your question on the crew web site. Did you not beleive what I told you and had to have a second opinion?
Old Apr 4, 2009 | 06:33 PM
Car: 89 Iroc
Engine: 5.7 TPI
thanks for the reply!
no i posted it in both places at the same time becuase sometimes i dont get an answer in one plce but the other i do. and im in progress of the sway as we speak.
but thanks for the quick reply to both of you!
Old Apr 4, 2009 | 09:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are two flywheels, a light-weight version (around 16 pounds) which was installed in higher performance cars, like the L69, and a heaver version (around 25 pounds IIRC) for crappers, like the LG4.
JamesC
Old Apr 4, 2009 | 10:18 PM
Car: 89 Iroc
Engine: 5.7 TPI
Perfect information!!! thats exactly what i was wondering!!!
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
gta90
Sep 15, 2015 04:00 PM
