Which Gear? Which Carrier
Old Apr 6, 2009 | 04:21 PM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
hey so i am looking at upgrading from stock..
should i throw in a 3.42 or a 3.73 whats the difference between the two?
and which carrier they seem to have the same description but is there a difference or not?
http://store.summitracing.com/partde...1%2DLR&FROM=MG
Or
http://store.summitracing.com/partde...5&autoview=sku
Or
Old Apr 6, 2009 | 06:03 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Which Gear? Which Carrier
We have to know what you're using the car for... 1/4 mile?
Old Apr 6, 2009 | 06:23 PM
big gear head's Avatar
The Lock Right is the best. The No-Slip has a bad reputation for failure. What gears do you have now and what do you want to do with the car. If this will be a street car then I recommend getting a new Eaton posi and the 3.42 gears. You will be MUCH happier with this. The Lock Right is good for an easy installation if the gears are not being changed. When changing gears then it is just as easy to install the Eaton. If you have a 3.08, 2.73, 2.56 or 2.41 gear then you will have to get a 3 series differential case or get the thick gear set. A new Eaton is $435 plus shipping.
Old Apr 6, 2009 | 06:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the FAQ About 10-bolts are the top of the page of info.
JamesC
Old Apr 6, 2009 | 07:40 PM
92RSStud's Avatar
Engine: 355CI
i already read the FAQ, thats why i posted... and not sure which gear set i have, i haven't pulled the cover off.
The Car is going to be a street/strip car.
why would the eaton posi be better than the lock-right?
Old Apr 7, 2009 | 07:05 AM
The Eaton is much smoother on the street and it's a little stronger.
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
