Clutch chatter Bad! HELP
Old Jul 19, 2001 | 02:33 PM
Rylos's Avatar
new matching clutch and plate throwout bering and fly wheeland input bearing (roller). No oil leaks!
Shifted into first worked great until about 30 minutes of driving. Started in first, dam near go throwen out of the car it shuttered so bad. Can somone tell me why this is still happing to this car after the new clutch etc.
If it were a horse it shoot it!. DAM !! Thanks in advance.!~
Old Jul 19, 2001 | 03:34 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
<font face="Verdana, Arial" size="2">...Can somone tell me why this is still happing ...</font>
It sounds like this is a problem that you had before. I had this problem too. When I did a clutch I had the flywheel surfaced. Same results, after a short drive it was back to its old ways. The theory I've heard is that the "hot spots" in the flywheel really never go away. The resurface helps for this short period but then they come back quickly and with a vengeance. If this is the case (hot spots on your flywheel) I don't know of any solutions (short of heat treating it, and that's all just theoreticall, as in, I don't have a clue if it can be done). You may be stuck with it or need a new flywheel to fix it. <shrug>
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
[This message has been edited by clemsparks (edited July 19, 2001).]
Old Jul 20, 2001 | 11:04 AM
Rylos's Avatar
I installed a new flywheel when the clutch was replaced! I posted an artical regarding the clutch pedal been stiff. Could this cause the problem? Its a T-5 305What to Type Emotion Graphic That Will Appear
Old Jul 20, 2001 | 11:05 AM
Rylos's Avatar
Fully restored 84 TA original factory spec (sucks) Mods when the kids grow up "Sigh" no money!
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
