Rear end help
Old Apr 10, 2009 | 08:28 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Rear end help
I want to put 3.73 gears in my car. Its a 10 bolt. If the rear gear size is a 7.5 or 7.75. Its a IROC-Z and 1987 that was org 5.0 tpi converted to 5.7.
Old Apr 10, 2009 | 08:51 PM
big gear head's Avatar
Re: Rear end help
The 7.5 is the GM 10 bolt and the 7.75 is the 9 bolt Borg Warner. You could have either one. Check the number of bolts in the cover. If it's the 10 bolt then you can get a 3.73. If it's the 9 bolt then you can get a 3.70. Either way you might need to replace the differential too. If you have the 9 bolt with 2.77 gears then you will need a 3 series differential. If you have the 10 bolt with 3.08 to 2.41 gears then you will also need a 3 series differential.
Old Apr 10, 2009 | 08:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear end help
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
