question about speedo gears
Old Apr 10, 2009 | 10:46 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Over the summer I plan on putting in posi and 3.73 gears into my 91 camaro rs with stock 5.0 v8 and 700r4 trans. I have been reading that this upgade will throw off my speedo so I would like to know what is needed to fix this. I know I will have to change the speedo gears but I don't know anthing about them so I don't know which ones to use. I have searched it but can't really find anything helpful. If anyone has done this upgrade will you tell me what you did to adjust the speedo.
Old Apr 10, 2009 | 11:03 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: question about speedo gears
http://www.partshp.com/speedometer_gears.htm
http://www.3rdgenformula.com/91/91speedometer_gears.htm
https://www.thirdgen.org/forums/tran...eter-gear.html
they may help ya
Old Apr 11, 2009 | 12:36 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
long story short, you need a 15 tooth drive gear, and the choice of driven gear depends on your tire size. 245/50R16 needs 44 tooth.
Old Apr 11, 2009 | 11:00 PM
Engine: 383 stroker
How hard is it to change these gears I plan on haveing a shop install my posi and 3.73 gears and I figure if it is not to expensive I'll have them fix the speedo while there at it Plus I have afte market 17" rims will that make that much of a diffrence in the speedo gears?
Old Apr 12, 2009 | 03:24 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The GM part number for the gray 15 tooth drive gear is 8642620. As for the driven gear, if you're running a 245/45R17, or 275/40R17, or 315/35R17 tire on the rear, then use a dark gray 44 tooth driven gear, GM part number 25513051. If you're running a 255/40R17 on the rear, use a light blue 45 tooth, number 25513052. If you're using a 255/45R17, or a 285/40R17, or a 335/35R17, then it's the purple 43 tooth, number 25513050.
Old Apr 12, 2009 | 06:07 PM
Engine: 383 stroker
thanks for the info it is a big help, is it relly hard to change the gears or I should say does it take a long time to do.
Old Apr 12, 2009 | 06:43 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Its really easy just pull the tailshaft housing off and switch the gear off the shaft and change the gear in the housing( you may need a new housing if your old gear is 38 and below teeth) the hardest part is taking the tailshaft housing off
Old Apr 13, 2009 | 12:13 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Not so. In the old days, each driven gear lived in a carrier that sits in the tailshaft housing. There were several different carriers, each serving 3 or 4 different driven gears, and the carriers were aluminum. We won't get into the whys, the OP doesn't need this info.
But these part numbers I gave for the driven gears, they include a new plastic carrier for each driven gear. Unless you're going off-roading on rocky dirt roads, the plastic isn't a problem. The new plastic carriers are almost as difficult to damage as the old aluminum carriers.
Old Apr 15, 2009 | 08:57 AM
Engine: 383 stroker
Thanks, for the info the part number you gave me, where can I find these parts a dealership or do you know of a good website?
Old Apr 17, 2009 | 12:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The part numbers I have are GM part numbers, I always just pay the local GM stealership's asking prices for speedometer gears, let them eat the shipping charges. Otherwise, I'd try www.gmpartsdirect.com
Old Apr 18, 2009 | 05:50 PM
Engine: 383 stroker
Cool, Thanks for the Help, I have 225/55R17 tires what gear would be used for them.
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
